Use this procedure to enable learning Security Binding Table (SBT) entries on all the VLANs where IPv6 DHCP snooping is configured.
Use this procedure to create a static SBT entry.
Switch:1> enable Switch:1# configure terminal Switch:1(config)#ipv6 fhs snooping static-binding ipv6-address 2001:DB8:89ab:cdef:0123:4567:89ab:cdef vlan 1000 mac-address 00:11:22:33:44:55 port 1/2
The following table defines parameters for the ipv6 fhs snooping static-binding ipv6-address command.
Variable |
Value |
mac-address 0x00:0x00:0x00 |
Specifies the MAC address of the binding entry. |
port {slot/port[/sub-port]} |
Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
vlan <1-4059> |
WORD<0-46> |
Specifies the IPv6 address for the binding entry. |
